I don't think there is any way to use a gear puller. I jacked mine up about 6" and, with nut loosened but still on, beat on the top of the spindle, with a piece of bar stock between the hammer and nut, till the whole assembly, tires,wheels, shaft and all, dropped out from under the gear. This also make it super easy to unbolt the wheel assembly from the shaft if your going to replace the bolster bushings.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
