Re: Q for Jim Nicholson gear puller??
Posted by glennster on April 14, 2011 at 07:34:12 from (75.57.126.3):
In Reply to: Q for Jim Nicholson gear puller?? posted by Cliff Grosberg on April 13, 2011 at 19:09:30:
you can use a 2 jaw puller and grab the outer housing at the flare out, put some tension on the puller and whack it with a hammer. or get a steel bar, drill the center, weld a nut on to make a puller , then bolt it to the holes that the top cover bolts down to.
