Re: 140 6 to 12 volt
Posted by Wayne A Johnson on April 14, 2011 at 14:21:23 from (69.207.56.32):
In Reply to: Re: 140 6 to 12 volt posted by janicholson on April 14, 2011 at 13:31:32:
There was two wires connected to the relay, 1 right from the battery and a smaller wire. I did disconnect the smaller wire so the only connection was, battery negative to ground, and battery positive to starter. I cleaned the ground to tractor again to make sure I was getting a good ground and even connected a jumper cable to the negative terminal and grounded that to another part of the tractor.the wire I disconnected goes to the starter switch. Those are the only two wires i saw connected to the relay. Thanks for all your help.
