Re: H hydrualics
Posted by Bob Rascoe on July 27, 2000 at 18:11:36 from (209.198.116.243):
In Reply to: H hydrualics posted by Charles on July 27, 2000 at 17:16:25:
The three stubs you are talking about . are they just caps ? If the Belly pump is in the tractor all you have to do is Get some pipe fittings and
rig hoses to your three point hitch . This is fairly easy . I did mine last year . Am rebuiling the engine now though . I used quick couplers
and I think the pipe sise was 1/2 inch pipe .
You should have a fill cap on top of the clutch housing for the oil for the hydraulics . Use the two front outlets , the second one back is for a delayed implement.
Good luck !!!
Post A Followup
: Re: Re: H hydrualics
