Farmall Tractors Discussion Board
Re: Re: 1928 Farmall Regular
Posted by Fred Mellott on January 04, 1999 at 13:42:03:
In Reply to: Re: 1928 Farmall Regular posted by Ron on January 02, 1999 at 19:18:25:
The information Charlie posted is correct for an F-20 but the Regular serial number in 1928 was stamped in the left frame rail at the front of the tractor around the raditor. Also the serial number is stamped on the engine block on the raised oval behind the mainfold. This number is only correct if the tractor is still equipped with the orginal block.
Post a Followup
: Re: Re: Re: 1928 Farmall Regular
