Posted by LRRifleman on April 15, 2011 at 12:40:54 from (107.26.251.187):
Hello!
I have a 1958 International Harvester Model 340 Utiity. When it was in the shop over the winter to repair the hydraulics, I had the shop repair the tachometer, which has never worked since I purchased the tractor. I know the tach is working because the "hour meter" IS moving. However, the tach needle bobbles extemsively as if it was indicating more the vibrations of the tractor. As it is running now, I can only "ball park" the rpms of the tractor (in a 400 rpm range). I can only presume this is not the way the tachometer is supposed to work.
Is there anyone out here that has an IHC that can tell me whether they can get a relatively precise RPM reading for their tractor? I am inclined to believe I need to replace the tachometer. Currently, my tachometer is reminiscent of a cheap compass caught between multiple magnetic fields.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
