Re: H rear wheel bolts
Posted by Yooper Farmall on April 15, 2011 at 13:31:24 from (141.210.112.16):
In Reply to: H rear wheel bolts posted by Doug Flory on April 15, 2011 at 12:54:54:
Actually Case-IH lists them as 5/8" x 4 1/4" bolts, they charge $13 each, for both rims that would be over $150 just for bolts. The thin nuts that go by the inner clamp? Case-IH wants $10 for each thin nut, so that is another $120. The outer nut you can probably get at a hardware store for less than $1, so after taxes you can probably get all set for less than $300.
Better solution:
Farmallhal pointed me in the right direction:
I just orded bolts from Norman Jackson in Greenfield, Indiana. Norm sells a 5/8" x 4 1/2" square head bolt for $3.50 each, and the thin nuts for $1 each and is charging me about $5 in shipping. I've ordered them, but haven't received them yet, I think my bill should be $65, I ordered the outer nut too.
Hope this helps.
