Re: H rear wheel bolts
Posted by rustyfarmall on April 15, 2011 at 13:43:30 from (209.152.78.140):
In Reply to: H rear wheel bolts posted by Yooper Farmall on April 15, 2011 at 13:31:24:
I guess it's been a few years since I bought the bolts, but not that many years ago, and I doubt if I paid more than a couple bucks each, including the nuts. The difference might be that I bought the 5/8"x 4 1/2" grade 5 hex head bolts. I did not want the square heads, even if I COULD have found them. I HAVE cut more threads on a 5/8" bolt so the nut would run down further, and it did work, but there was a noticeable step in the diameter where the factory threads ended and my newly cut threads started.
