Re: 254 overheat problem solved
Posted by Janicholson on April 17, 2011 at 08:47:32 from (67.72.98.46):
In Reply to: 254 overheat problem solved posted by glennster on April 17, 2011 at 02:12:05:
It can be painful working on someones bad technique. It will be fine. Jim
