Re: Farmall 100 hydraulic pump rebuild
Posted by achodges1 on April 17, 2011 at 19:08:56 from (64.123.191.249):
In Reply to: Farmall 100 hydraulic pump rebuild posted by Nickd on April 17, 2011 at 18:01:19:
You have to put the shaft through the bushing before you put on the sleeve.
