Re: Farmall 100 hydraulic pump rebuild
Posted by Nickd on April 18, 2011 at 06:49:12 from (75.117.130.15):
In Reply to: Re: Farmall 100 hydraulic pump rebuild posted by achodges1 on April 17, 2011 at 19:08:56:
That looks like it will work, but assembly may be a challenge. I"ll give it a try.
