Sounds typical for a system staying on demand . Like others suggested, make sure your single and double action setting on the aux valves are lined up, no bent or broken roll pins. If that checks out you will need to take the four bolt cover off regulator, relief valve assembly. Note, heavy spring under cover for relief valve so take out two corner bolts and put longer ones in to avoid things flying apart. You will find a screwdriver head orfice with screen . Depending on how many times it has been repaired over the years, the original had a roll pin through the orfice holding a check ball in place. This check ball bounces back and forth and closes the orfice down. As this is a hardend seat they are difficult to re drill to proper size but can be done. It is only .031 so you need wire gauge drills to do so. Screen most likely is collapsed and plugged, you can cut off bottom to clean and wrap it back up again if it is not broken. Now for the fun part. Sometimes you have to make the hole in orfice slightly larger to compensate for the wear on the lands in the control valves, mostly the hitch valve is the problem. I usually go for about .040 to start with, as if you go too large your system will not pressure up when you use the valves. But first off, clean orfice, throw away the ball, and try that with original size. You will need a new gasket and also replace the o-ring on regulator piston and polish it up nicely.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
