TD-14 Series 142
Posted by Texas Denny on April 18, 2011 at 15:36:23 from (74.84.29.153):
I just bought a TD-14 Series 142. We started it today and it ran pretty good for 10 minutes. It then died. We discovered that someone had turned off a valve at the tank and we obviously drained the system running it. I have bled diesels before with good results but wasn't able to this time. I got excellent flow out of the bottom of the rear filter and somewhat less out of the front filter but no air from either. When I opened the top of the rear, I got nothing. When I opened the top of the front filter, I get nothing. Does anyone know the correct order of bleeding this tractor? Does it need to be running on gas to bleed it? Is there a pre-pump on the back of the injector pump that pushes the fuel through the filters? Never worked on a gas start diesel.
Sure could use some help. Thanks.
