Re: TD-14 Series 142
Posted by Wardner on April 18, 2011 at 17:02:03 from (209.86.226.61):
In Reply to: TD-14 Series 142 posted by Texas Denny on April 18, 2011 at 15:36:23:
It may take awhile for fuel to bleed out the top of the filters. You can remove the bleeder petcocks and place a square cut hose on the threaded hole and suck. Shouldn't take long to get fuel.
Yes, there should be transfer pump on the end of the injection pump that draws fuel from the primary filter and sends it to the secondary filter.
I make this recommendation not knowing what the filter arrangement of the 142 series looks like so I may be wrong. But consider using vacuum somewhere.
