Re: 424 lift problems
Posted by Jimb2 on April 18, 2011 at 19:20:19 from (99.240.236.11):
In Reply to: 424 lift problems posted by Matt L on April 18, 2011 at 18:43:41:
Hi Matt, did you clean the suction filter on the end
of the suction tube(large) in the hydraulic housing
under the seat?
If it has power steering, could be the flow divider
is letting most of hydraulic flow go to PS instead
of splitting off about 3 GPM for PS.
JimB
