424 lift problems
Posted by Matt L on April 18, 2011 at 18:43:41 from (50.37.117.162):
Messed with my 424 again yesterday. Still having problems with my 3 point working correctly. I checked the filter under the column - its clean. Did find the top link spring is broken. Messed with the adjustment and its still the same. Tried tricking it too.
Lift works fine cept its weak. Wont lift my back blade unless I rev the snot outta it. The cylinder seal should be good since it doesnt bleed down at all - even after a week of sitting. I even played with the lever for the remote. Nothing changes it. Pump doesnt get hot when its running either.
Bout outta ideas. All thats left is the pressure relief valve and the other filter - which I think would be clean too. The whole system is really clean from what Ive seen.
Anyone idea's on fixing this?
