Re: Farmall Cub serial numbers
Posted by colin caissie on April 23, 2011 at 04:24:43 from (68.238.48.199):
In Reply to: Re: Farmall Cub serial numbers posted by Art Massing on April 22, 2011 at 17:19:07:
I did find the casting number on the block. So if I interpret the date, I can be sure of the internal parts? I'll plan to get into the parts and mike them. What are the big issues re: incompatibility? i.e. are all gasket sets the same? All .020 over pistons the same, etc?
Probably measure in place, then if it needs block boring, take it apart.
I'll be researching this, but any quick sources for model i.d.?
Thanks,
Colin
