Re: 656 diesel batteries
Posted by karl f on April 27, 2011 at 18:27:07 from (156.99.196.169):
In Reply to: Re: 656 diesel batteries posted by mkirsch on April 27, 2011 at 05:39:28:
or is it even the right regulator? or is it still needed due to on the farm modifications...
There were 2 charging systems on 656s: generator vs. alternator; both use regulators and the regulators are not interchangeable although anything is possible. You could also have a more modern alternator added on the farm that doesn"t require the regulator, which means it needs service itself.
hope you figure out which system you have!
karl f
