H water pump pulley
Posted by Robin Hood on April 28, 2011 at 12:05:33 from (24.229.11.52):
Was changing the belts. Got the generator pulley to tighten like it's supposed to. Water pump pulley adjuster is giving me a fit. There was no set screw in the threaded hole on the front half of the pulley(closest to the fan)5/16 by 20. Am I correct in assuming that all I have to do is turn the pulley halves together clockwise to tighten the belt. Can I put the heat wrench on the pulley a little with out burning up the seal?
Thanks for your input.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
