Posted by Crazy Red Power in SE-WI on April 28, 2011 at 13:22:10 from (24.183.132.223):
In Reply to: H water pump pulley posted by Robin Hood on April 28, 2011 at 12:05:33:
I just freed one up last year. I sprayed penetrating oil in the set screw hole & around the outside of the pulley flange. I waited 5 - 10 minutes & tapped on the outside & top of the flange. Then I used a long, flat tip chisel & tapped the pulley in both directions (CW & CCW) until I could turn it by hand. I wiped the penetrating oil off, put the belt back on & turned the flange clockwise until the belt was at the right tension & set the screw. I don't recall the amount of deflection on the belt, maybe an inch... I think. Anyway, this was my way of doing it, as I don't own a smoke wrench, yet.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on
... [Read Article]
Latest Ad:
[More Ads]
