Posted by Janicholson on April 28, 2011 at 14:21:39 from (72.215.119.13):
In Reply to: 240U starter posted by IH fan on April 28, 2011 at 12:30:26:
Make sure the new style drive is installed. Check the ring gear (in the hole where the starter was removed) if the teethe at the spot where the starter engages is more than 30% or so worn off (tooth length) I would recommend replacing the ring gear (splitting is needed to do that). If the teeth are still pretty long but flattaned and burred over, using a dremel tool to dress them to make a clean tooth shape is a good idea. The teeth will be worn 180 degrees away from that location where the engine stops naturally with the pistons about 1/2 the way up. (or down) Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
