Posted by Janicholson on April 29, 2011 at 19:39:55 from (72.215.114.55):
In Reply to: Loader cylinder kit? posted by AF 70 on April 29, 2011 at 19:01:25:
Cylinders that leak down and do not show oil on the outside are usually double acting cylinders that have a return/reservoir hose hooked to the top of the cylinders. If it is single acting, (no down pressure) and lowering, and no top of cylinder hose, and not leaking out the top, it is probably the pump, or valving. the failure to lift is also an indicator of pump issues. What cylinders are on it. Which type of pump, and which valve? Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
