Re: Loader cylinder kit?
Posted by rustyfarmall on April 30, 2011 at 06:39:49 from (216.248.71.224):
In Reply to: Loader cylinder kit? posted by Janicholson on April 29, 2011 at 19:39:55:
The cylinders on the #30 and #31 loaders are not double acting cylinders, but they DO have 2 hoses. One at the rear, and one at the front. The front portion of the cylinders serves as a reservoir to increase the capacity of the belly pump. As the loader is being raised, the oil in the front portion is pushed out, through the hoses which are connected to a "tee" fitting installed on the belly pump fill pipe.
Yes, it is possible for the hydraulic oil to leak past the pistons and seals inside the cylinder and never appear as a leak on the outside.
