Posted by Bob M on May 02, 2011 at 07:33:16 from (67.240.171.41):
In Reply to: Farmall B advise posted by 4 bottem on May 02, 2011 at 05:11:24:
Ed - The stock 6 volt starter on my Super M has been on a steady diet of 12 volts for nearly 35 years. It's still going strong. If your starter is in good shape it too will last a LONG time on 12 volts.
You can modify your existing magneto to work as a distributor. You'll need to purchase/mount a generic "12 volt" (self-ballasted) ignition coil - about $20.
Inside the mag disconnect the mag coil wire to the breaker points. Now connect new coil primary to the mag's breaker points. Finally connect the new coil's output to the center tower on magneto cap.
Like JimN mentions, you'll also need a different ignition switch. (The stock mag "ignition" switch has only one terminal which it shorts to ground in the off position.)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
