Re: Farmall B advise
Posted by sflem849 on May 02, 2011 at 10:13:31 from (69.197.84.78):
In Reply to: Farmall B advise posted by Bob M on May 02, 2011 at 07:33:16:
Can you do that with a mag that isn't hot? ie bad mag IIRC the OP had a "bad" mag. This could mean a lot of things.
OP - Did you check to make sure the points wern't welded shut? I've seen it happen before.
