Re: More ?'s on my 806 brakes
Posted by Aces on May 02, 2011 at 18:49:49 from (66.172.225.113):
In Reply to: More ?'s on my 806 brakes posted by Dave from MN on May 02, 2011 at 15:50:40:
FC Andy I don't have your answer, it would seem to me if the wheel turns ok with engine off. Then the brake dic should be ok. The valve must be sending oil to the brake with engine running. I believe you said you took brake valve off the 1206 and but on the 806 with no luck. Try the MCV off the 1206 If the helps I would say that is it.
