Re: More ?'s on my 806 brakes
Posted by pete 23 on May 03, 2011 at 10:37:09 from (74.44.100.190):
In Reply to: More ?'s on my 806 brakes posted by Dave from MN on May 02, 2011 at 15:50:40:
I can't see how your brakes would apply with that little pressure if you can stop flow with your finger if you have good return springs in side the brake as they are quite heavy. If you had wrong seperator plate they would lock without running if you could even get the outer drum tightened down.
