Re: H rear rim alignment
Posted by Nebraska Cowman on May 04, 2011 at 05:11:39 from (66.252.115.12):
In Reply to: H rear rim alignment posted by NDS on May 04, 2011 at 04:46:28:
Pins? generally there are blocks riveted on like these. You could weld something on. Of course you will have to remove the tire.
third party image
