H rear rim alignment
Posted by Kevin W on May 04, 2011 at 04:46:28 from (148.168.40.4):
After putting the rear rims and tires back onto my "43 H, I neglected to retorque the hub to rim clamps and consequently the left hub spun slightly under a load inside the rim knocking off one of the two alignment "pins" from the rim. It appears that they are pressed in, as there are perfect holes in the rim, with no tear in the metal. Can these pieces still be had. CIH parts page doesn"t show any such animal. Thanks, Kevin
