Re: H rear rim alignment
Posted by mkirsch on May 04, 2011 at 05:26:52 from (64.80.110.75):
In Reply to: H rear rim alignment posted by Kevin W on May 04, 2011 at 04:46:28:
IH didn't make the rims.
Rims were made by third-party manufacturers like Unverferth.
Frankly, I would sincerely doubt if you could get just the "pins." It's either the whole rim, or nothing.
Regardless of what you do, you'll have to remove the tire to replace the piece. It was riveted, not pressed.
