Re: H rear rim alignment
Posted by Andrew Z on May 04, 2011 at 06:31:01 from (64.252.115.246):
In Reply to: H rear rim alignment posted by Kevin W on May 04, 2011 at 04:46:28:
Just weld a stop block on like Cowman says. All the new rims made have welded blocks by the way.
Andrew
