Re: 1952 Farmall Super A engine shuts off
Posted by d beatty on May 04, 2011 at 08:47:37 from (71.239.246.137):
In Reply to: 1952 Farmall Super A engine shuts off posted by Jim Linville on May 04, 2011 at 08:32:12:
When it shuts off will it restart right away? If it restarts right away it could be something floating around in fuel system or maybe float wanting to stick. If it has to cool down to restart you may have a coil or condensor breaking down.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
