1952 Farmall Super A engine shuts off
Posted by Jim Linville on May 04, 2011 at 08:32:12 from (71.58.159.243):
When the engine heats up under heavy load (discing or plowing)the engine shuts off.
I've checked, cleaned, set the ignition but the problems remains
Setting the choke about 3/4 appears to provide some improvement but the engine will still shut off.
Thinking it's a fuel issue, I've checked the vent in the fuel tank cap which seems ok.
Could it be the Ethanol Fuel? With a hot engine, something like fuel vaporizing?
I'm not familiar with checking/setting the carburetor.
Any suggestions?
Thanks in advance,
Jim Linville
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
