Re: 1952 Farmall Super A engine shuts off
Posted by old on May 04, 2011 at 09:57:42 from (4.245.14.140):
In Reply to: 1952 Farmall Super A engine shuts off posted by Jim Linville on May 04, 2011 at 08:32:12:
If it takes about an hour to do that then it might be the coil check for spark as soon as it shuts down do not wait even 5 minutes. No spark then most likely the coil. If you have spark then carefully because of it being hot double check you have a good gas flow from the drain plug in the bottom of the carb. Also make sure the fuel line is not to close to the manifold so as to get hot and boil the gas in the line causing a vapor lock
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
