Re: 1952 Farmall Super A engine shuts off
Posted by NawlensGator on May 04, 2011 at 12:31:15 from (52.129.8.50):
In Reply to: 1952 Farmall Super A engine shuts off posted by Jim Linville on May 04, 2011 at 08:32:12:
My first hunch would be the coil. I've had them shut down and the coil would be too hot to hold your hand on. Replaced the coil and ran fine.
If pulling the choke helps, my second hunch would be a fuel flow restriction. Either the tank, bowl screen, or carburator screen.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
