Re: H rear rim alignment
Posted by John M on May 04, 2011 at 15:50:51 from (67.231.169.173):
In Reply to: H rear rim alignment posted by Kevin W on May 04, 2011 at 04:46:28:
Ive got to wonder if your working the snot out of! Youve got another one, loosen the lugs, spin it around until it stops them tighten them back up again. Just make sure you retighten them. BTDT and have one like that now,
