Re: More on the Farmall 450 electrical problem
Posted by Janicholson on May 04, 2011 at 18:08:17 from (199.17.6.77):
In Reply to: More on the Farmall 450 electrical problem posted by P and R Pete on May 04, 2011 at 16:39:31:
The battery needs to be tested for amp productivity, but the issue is in connections. That Relay (often called a solenoid, but it is a relay in fact) is toast. it has high resistance internally and smokes as a result.
Trash it, and a new one is cheap. If the new one has 4 terminals use the S terminal for the wire to the button.
It needs new 0gauge or 00gauge battery cables made to fit (welding cable is great, car cables are not allowed.)
It will crank like a deamon with these mods. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
