Posted by janicholson on May 04, 2011 at 18:27:50 from (199.17.6.77):
In Reply to: H fan belt adjustment posted by Eric Allen on May 04, 2011 at 18:11:08:
Many additional stories in the archives. The top pulley is an adjustable shiv. the front 1/2 of it spins (when persuaded) to allow the belt to drop way down in to get it on the bottom pulley. Take out the set screw. Put good penetrating oil on the threads of the pulley 1/2, and the removed set screw hole. Wire brush the threads and apply more juice. heat the flange with a propane torch and drive the flange around with a brass punch on the setscrew boss and the boss opposite that. Back and forth back and forth, be gentle, it is possible to break it (not good). when it starts to move, go back and forth more before continuing to loosen. When putting it back together, do not tighten it much, pushing with your thumb very hard on the middle of the belt between pulleys should result in at least 1-1/4" deflection. It is designed to be looser than any car belt. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
