Re: 1952 Farmall Super A engine shuts off
Posted by blunted on May 04, 2011 at 18:38:58 from (205.188.116.73):
In Reply to: 1952 Farmall Super A engine shuts off posted by Jim Linville on May 04, 2011 at 08:32:12:
for one thing, i would;nt use ethanol. it burns to hot. and the coil sounds rite , or condenser. set carb at 1 and half turns out and ajust warm in or out. rubber particals can interupt the fual flow so like said, if it starts up after it shuts down, clean carb and put on metal lines and new carb kit. remember, these old engines was made to run with lead. not ethanol
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
