Re: More on the Farmall 450 electrical problem
Posted by teddy52food on May 04, 2011 at 18:45:39 from (68.169.216.43):
In Reply to: More on the Farmall 450 electrical problem posted by P and R Pete on May 04, 2011 at 16:39:31:
That starter is dragging, causing the solinoid to get hot from too much amperage. If you put the booster cable on the starter side of the solinoid, then ground the other cable(make sure is is out of gear) it should spin with a car battery, if you have good heavy cables. If it doesn't turn fast, rebuild the starter, mainly the bushings.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
