Re: More on the Farmall 450 electrical problem
Posted by Owen Aaland on May 04, 2011 at 19:16:25 from (216.47.32.42):
In Reply to: More on the Farmall 450 electrical problem posted by P and R Pete on May 04, 2011 at 16:39:31:
If you know how to use a volt meter you can find the problems instead of just throwing parts at it. With the starter engaged there should be no more than .1 volt drop in any wire, .2 volt drop through any connection, but no more than about .5 volts drop from the battery post to the starter terminal. Also check the grounded side. You should have no more than about .2 volt drop between the starter and the battery post. Battery voltage during cranking should not drop below 9 volts. Starter amperage draw can be determined by reading the battery voltage during cranking and then have the battery load tested to the same voltage and read the amperage.
