Re: farmall 400 power steering problem
Posted by Janicholson on May 05, 2011 at 07:37:37 from (199.17.6.160):
In Reply to: farmall 400 power steering problem posted by aaron brown on May 05, 2011 at 04:48:25:
The problem is either that the priority valve you are using is open, or you do not have one in the system. They are available IH, or from Surplus Equipment, or many other suppliers. When you operate a non used valve, you create the needed pressure in the system. A priority valve does that. Jim
