Re: Continental engine hard starting
Posted by jb706 on May 05, 2011 at 14:13:43 from (207.118.208.49):
In Reply to: Re: Continental engine hard starting posted by jb706 on May 05, 2011 at 14:07:07:
I also know it is not electrical. the plugs are dry after trying to start it several times. it is a fuel issue. if I pull the air hose off and hand choke it, it starts much better. I will check the float again but that shouldn't really affect starting. It will not even attempt to fire unless the throttle is all the way down. I am still wondering if the plug missing on the bottom of the carb is causing an irregular air flow and therefor not picking up fuel?
