Re: 6 Volt Questions
Posted by Pat-CT on May 07, 2011 at 23:33:28 from (137.36.48.20):
In Reply to: 6 Volt Questions posted by Fullers Farmalls on May 07, 2011 at 22:43:56:
Not quite sure what you mean by no.2 However, if you can find some high strand wire you could go smaller then 00. I have Smaller high strand wire on mine and it cranks with no problems. Welding wire i believe is to be high strand and should work good. Make sure all connections are clean. However if you H is taking long to start i would look else where. My H can sit for 3+ months in the garage and start in 2-3 cranks.
