6 Volt Questions
Posted by Fullers Farmalls on May 07, 2011 at 22:43:56 from (72.77.115.38):
I have an H that runs on 6 volt. Its hard to start to say the least. I've had the carb apart to work on it. And everything is good there. I have a good battery putting out 6.2 volts when its not hooked up and when it was barely charged. I know they have to have big cables. My cables get hot and reading on here I know they are probably a bit small. My question is can i use number 2 wire. Not 2 gauge, number 2 wire. The big heavy stuff or will this be to much? Also I have some misc wire laying around hows an easy way to measure the wire size? Finally whats the best way to solder the terminals onto the cable? Thanks as always -Keith
