Re: 6 Volt Questions
Posted by oldtanker on May 08, 2011 at 06:56:13 from (66.228.255.223):
In Reply to: 6 Volt Questions posted by Fullers Farmalls on May 07, 2011 at 22:43:56:
The bigger wire the better. Less ohm loss per foot and reduces heating of the cables. Factory made cable or soldered. Don't not use the clamp type fill all battery clamps. Those are designed to be a tempory emergency fix. Also everything "clean tight and brite" as far as all of you connections! I know of people who go so far as to removing the stater and cleaning the starter to block/bell housing mating surfaces.
All of the above will reduce voltage drop when cranking allowing the ignition system to get more voltage unless you have a magnito instead of a distributer.
If it's still hard starting then there is a problem someplace else like weak spark of fuel.
Rick
