Re: 6 Volt Questions
Posted by John T on May 08, 2011 at 07:47:19 from (173.243.189.183):
In Reply to: 6 Volt Questions posted by Fullers Farmalls on May 07, 2011 at 22:43:56:
On 6 volt systems, especially like an H versus a little Cub etc., its CRITICAL that all battery, ground, starter and switch connections be clean bright n shiny with quality connections cables and terminations. I recommend 0 better yet 00 Gauge Battery n Starter n Ground Cables and have a good solid frame ground connection (or even close to the starter) NOT any wimpy thin rusty sheet metal part. Dont forget the switch can be a cause of heat and voltage drop and poor cranking due to burned carboned contacts.
John T
