Re: New to me Farmall NEED INFO - SAVED FROM SCRAP YARD!!
Posted by RTR on May 08, 2011 at 10:39:47 from (74.248.177.122):
In Reply to: New to me Farmall NEED INFO - SAVED FROM SCRAP YARD!! posted by LRRifleman on May 08, 2011 at 10:27:41:
Ok. THANK YOU SO MUCH! I thought it looked like the same engine, but wasn't sure cause the hydraulic block is different.
I am open to ALL and ANY information and suggestions you all have on this tractor. I look forward to hearing from you all soon. I am about to go outside and look for the serial number plate and take a closer look at everything else to see if it might have power steering, etc. Be back soon!
