1952 Super M Head #
Posted by BUCK CLAYTON on May 09, 2011 at 16:04:07 from (70.189.103.242):
MY 1952 S M Head # is 362174-R1.There is no cylinder head breather tube or connection at back of head to connect to air cleaner, but it does have inlet fm. gov. pipe. I tapped back of valve cover and added pipe to air cleaner. Works good. SM parts book shows 356994-R92. What have I got here. The block # is 356980R1, books shows 356981R93. Compression about 145 lb. per cylinder. Thanks, Buck Clayton
