Re: 1952 Super M Head #
Posted by D Slater on May 09, 2011 at 19:59:57 from (184.15.26.40):
In Reply to: 1952 Super M Head # posted by BUCK CLAYTON on May 09, 2011 at 16:04:07:
Randy answered the head question. 356994R92 is the part # for a replacement head assembly with valves, springs,spring retainers and rotocaps. That head casting is 8574DC. 356981R93 is a replacement block assembly. Casting # on that block is 365586R1.
356980R1 engine blocks came in SM, SMTA, part of the 400 tractors and W series in the same time frames.
To see if that block is probably original to the SM. Check the date code on the block or see if that engine serial # was installed in a tractor the same month tractor was built.
